NoCoSPL
A Daily Loud Trunk
Pmed!!!!!!!!!!!You need some?? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
how much were those rolls?only wire //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
end up where i didYou need some?? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I can get you some if interested. Decently priced as well.how much were those rolls?
You honestly don't believe everything you read, do you? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gifend up where i did
Were some of them words english? //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif one hell of a giant run-on.a 16v setup charges at 18 to 19.3 depending on user seting on the external regulator and the kinetiks are 3 post 1 ground 1 12volt and one 16 volt side system off the 16v side 12 side on car/truck all alts charge 16v the battery acts like a step down cause the 12 volt side is hook up a couple cells early equils less power new concept but for it to work without a problem you need all the batterys to be link at all three post groung all together 12 volt all together 16 volt all together so you dont get a voltage differenchale and burn up batteries that why they burn up a bubble up inproper use and install im doing 4 270 amps alts and 8 kinetik 16vs in my truck but charging at 18.5 to keep the wear and tear on them down and bus baring them right by my amps 7 batts in back 1 up front 1 oga ran from the 12 volt side to the bus bared batterys in back 12v side and 4 5 runs all the way back 1 of each alt and one of the front batterys 16v side and one run from one alt to front battery and 1 or more oga ground from the alt brack to the back batterys and 2 runs from back batterys to frame and there a ground from the bracket to the frame and to the alt bracket and to the front battery = charge system from hell lol
i get the 4/0 at 4$ a footI can get you some if interested. Decently priced as well.
heres a lil something I wrote up to make a 16v set up work without a 3 post kinetikeverything...lol. Im thinking about running a 16 volt system for next summer. Your charging system is going to be charging at 17ish or so, right? So this will charge every cell in the battery, and then for your lights, cd player and all that, youll just hook it up to the 12 volt post?
How can you run a 16 volt system when that batts just have two terminals btw, if you dont mind explaining it to me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks
4/0 for 4 a ft? i get it for 2.50 son! loli get the 4/0 at 4$ a footand the 2/0 25ft for 25$
but thats welding cable
Not bad. Used to use 4/0 and 2/0 since I got it on the cheap. But I rather work with the flexability of a wet noodle. That 2/0 flexa-prene I had was junk. I am never going back to welding cable.i get the 4/0 at 4$ a footand the 2/0 25ft for 25$
thats not birch nor oak..Birch aint cheap!!
