Walk-through < 8 15's
only wire //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
how much were those rolls?
a 16v setup charges at 18 to 19.3 depending on user seting on the external regulator and the kinetiks are 3 post 1 ground 1 12volt and one 16 volt side system off the 16v side 12 side on car/truck all alts charge 16v the battery acts like a step down cause the 12 volt side is hook up a couple cells early equils less power new concept but for it to work without a problem you need all the batterys to be link at all three post groung all together 12 volt all together 16 volt all together so you dont get a voltage differenchale and burn up batteries that why they burn up a bubble up inproper use and install im doing 4 270 amps alts and 8 kinetik 16vs in my truck but charging at 18.5 to keep the wear and tear on them down and bus baring them right by my amps 7 batts in back 1 up front 1 oga ran from the 12 volt side to the bus bared batterys in back 12v side and 4 5 runs all the way back 1 of each alt and one of the front batterys 16v side and one run from one alt to front battery and 1 or more oga ground from the alt brack to the back batterys and 2 runs from back batterys to frame and there a ground from the bracket to the frame and to the alt bracket and to the front battery = charge system from hell lol
Were some of them words english? //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif one hell of a giant run-on.
everything...lol. Im thinking about running a 16 volt system for next summer. Your charging system is going to be charging at 17ish or so, right? So this will charge every cell in the battery, and then for your lights, cd player and all that, youll just hook it up to the 12 volt post?
How can you run a 16 volt system when that batts just have two terminals btw, if you dont mind explaining it to me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks
heres a lil something I wrote up to make a 16v set up work without a 3 post kinetik
http://www.caraudio.com/forum/showthread.php?t=442237
i get the 4/0 at 4$ a footand the 2/0 25ft for 25$
but thats welding cable
Not bad. Used to use 4/0 and 2/0 since I got it on the cheap. But I rather work with the flexability of a wet noodle. That 2/0 flexa-prene I had was junk. I am never going back to welding cable.
got some more stuff
Dont want to say how much that **** was //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Best $20 ever spent in my life //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Got most of it cut up and ready to glue.. Just got back from the movies though and too lazy to get pics //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
Good luck. Front facing USB it's rare and it's not hard to reroute a USB from the rear. 300 isn't enough for any quality touch screen with 3 sets...
10
Stream? Unlikely https://www.smsl-audio.com/portal/product/detail/id/809.html https://helmaudio.com/products/boltdac You might can stream in...
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
TnT_Sounds
profiling gets **** done!
TnT_Sounds
Colorado
AcidikBass20
