So, for my example, I research on the internet to find a driver that is out of the power ratings that I have tested so far....something that can handle more. I came up with using the RE AUDIOXXX15d2 driver. i will be using 6 of these wired to a 1.4ohm impedance for maximum power transfer from a low resistance amplifier, such as the common 1 ohm stable amplifier. Now, I do not recommend using too many drivers on a single amp, but for this example, I will only be simulating a single amp to power these beasts.
One thing to know about amps and power distribution is that there is a reason they are called amplifiers, and not voltifiers. Because when dealing with multiple drivers, such as this example of 6 15s, the voltage will be distributed equally to each driver, as long as they are all of the same resistance, such as in this example: each one is 4.2ohms per coil. So, giving my calculations for these, I came up with a musical voltage level of 38.53V and a peak voltage of 54.49V. In order to set this voltage correctly, I need to know the free-air resonance of the driver(s), which is 19.1Hz. So, this says that I can test this voltage out on these subs when not installed at 38.53V and they should not reach xmech or thermal limits and should play very efficiently. BUT, in order to do this test, I need an amplifier that will supply the power correctly.
One thing that many people do not look at when purchasing an amplifier is the amp ratings. The fuses can tell you what the maximum ampere levels the amplifier may be capable of in most good built amplifiers, but overall the construction of the circuits and the transformer usage within the amplifier will tell the tale of any amp. But for sake of not being able to open the amp up, or purchasing anything until something is known, we can use this fuse rating and the specifications of the amp given by the manufacturer as a reference, as we will have nothing else to go by unless we know of someone who has used the amplifier and tested its capabilities out that could inform you of its actual performance. We have no way around this dilemma, so we need to make the best of it.
So, using the figures of amplifier efficiency, we will not base it on wattage, as some car audio shops do, but more so the amperes that it can put out. This is a very important factor when knowing how an amplifier can provide power without damage. So, we will calculate the amperes needed for these drivers at 38.53V@1.4Ohms. For this, I come up with 27.518A. That is pretty good for 6DVC drivers rated at 2000Wpeak each. So, now we need to find an amplifier that will provide over 38.53V continuous without exceeding 27.518A, as this will cause heating issues with the amplifier and a high possibility of damage over time.
For this, I have calculated a final wattage of 1060.18W needed at this resistance level, because the 2000W each peak is likely tested at series connectivity to show its maximum power consumption. Manufacturers can use this to show high power handling capabilities. But once resistance is lowered, it requires less power to operate them efficiently. make sense? So, that is why only 1060.18W is needed for all 6 2000W peak drivers!
So, I need an amplifier that can produce the 38.53V@= 27.518A. Doing more research on this, I found on the same site, the xtx3000.1 amplifier to work with this configuration. The amp specifications state that it can produce 1400W@1ohm, which I found to be conservative, because I have calculated it to be around 1484.7W@1ohm, which will give us ABOUT 38.53A to utilize efficiently. So, far so good. But, what about @ our needed 1.4ohms resistance . We get about 31.623A of usage and a power distribution of about 44.27V, which gives us a wattage of 1400W@1.4Ohms, which the amp states that this can be done @1ohm. Pretty close to the manufacturer specs. So, these amps seem to be rated very well.
Now, if we hook the drivers up in a series/parallel/parallel connection, we get our 1.4Ohms from this, and we have an amplifier that can produce a max ampere level of 31.623A efficiently, and we only need 27.518A of that, as well as it having the capability to produce over our needed 1060.18W, which it will give us about 1400W to use. This amp will work well for 6 of these drivers in this configuration.
That is the example I have came up with so far to use, but not being able to test it, yet. I have a couple of JLW3 10s lying around and a kenwood amplifier setting in the foyer to possibly hook up to test everything out. As long as I calculate the kenwood amplifier to be able to match the subwoofers in output and amperes and wiring possibilities, then this can be proven soon.
Next post will be the other stage of the gain settings for the voltage levels of this example.
NOTE: Since this was an example, resistance is an example as well. Actual resistance can be calculated for different configurations if needed. Again, this is just an example.
