2003 Honda Accord wire routing help please
Spike243
Ok I have a 2003 honda accord v6 6speed without navigation and i am just completely lost on how to get the power wire through the fire wall. I have looked all over the web and all the pictures I find are not helping me //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I would really appreciate it if someone could help me on where to route the wire. Pics would help greatly. Thanks in advance
pull carpet up under the drivers and pass side and see where the factory wiring is coming from..Helped a friend last weekend in a 05 mustang and his wires were run threw the body so we had to drill a hole and run them in via that way. To use the factory location we would have to remove tire and wheel well to get to it so we said screw that
I can see where the factory wiring goes through but it is just plain terrible to get to as it is in the middle of the vehicle and blocked by lots of stuff. I am open to drilling a hole and using a grommet but i want to know where a safe spot would be
In my 93 Acura I had, I ran it on the pass side up high of the rt side of the floorboard.Just below the windshield motor under the hood, cut a slice in the rubber garment.Not sure that it would be the same concept as the accord, but it may be.Then ran down pass side to dist block in the rear.But Look just under the window wiper motor.I ran a Coat hanger to see if it went through ok,But That Insulation is pretty thick, why I used a Heavy ga coat hanger.Will have to peel that insulation back though.This is what I did, and left enough under the hood to attatch my 4ga run,and continue to pull through, in which was all I needed.
In my buddies 06 accord we drilled a hole that goes into the driver side wheel well and then routed it up from there to the battery. Not the ideal solution but if the wire stays taught you are fine.
located just above the gas pedal behind the sound barrier is a perfect spot to pass wires. in some there is an unused grommet a bit higher on the dash. in others there is a small horseshoe symbol. find a flat spot, locate visible penetrations on both sides, and drill.
Alright ill check there tonight when I have some time. Any pictures by chance?
Spike243
Spike243
Montana
Spike243
