voltage display meter
3 wires:
One is ground
One goes to the battery
One goes to a switched power source (eg, ignition)
where do i find that wire?
if i hook up the + and - from the battery to the + and ground wire, will that work?
It all depends on how many wires there are. I looked @ the manufacturers' website, and it didnt say.
If there are only 2 wires, then one is ground and one is switched. A switched wire can be found many places. Fuse box, anything that turns on only when the key is turned (ignition)
Fuse taps would be the easiest.
Ali1
e6300 FTW
Ali1
U.S.
ultimate157
