OP
Dub7sonoma Premium Member
Premium Member
- Thread Starter
- #46
You just mad cause I'm louder than your blazer with a 900 watt amp lolLol. Next started thread by OP: "Why did my amp blow?"
I don't consider anything I own to be expensive. And what have I posted that was wrong?Op thinks just because he can afford expensive equipment he knows what he is doing.Lol what a moron.
Running a non capable amp at .25ohm and thinking it's a fusing problem.I don't consider anything I own to be expensive. And what have I posted that was wrong?
So then what was the problem genius. The fuses were popping because too much current was being pulled into the board. Only way to solve it (and stay wired at .25 ohm) is......... Bigger fusing or none at allRunning a non capable amp at .25ohm and thinking it's a fusing problem.
This is what I got out of itSo then what was the problem genius. Only way to solve it -i thought there was no problem
(and stay wired at .25 ohm) - well there's your real problem
Then the board can't handle the current Then the board fries.dude do you even know ohms law?So then what was the problem genius. The fuses were popping because too much current was being pulled into the board. Only way to solve it (and stay wired at .25 ohm) is......... Bigger fusing or none at all
Yea i know ohms law, but has the board fried yetThen the board can't handle the current Then the board fries.dude do you even know ohms law?
