UNLIMITED BATTERY, Easy to do, just see
Fuck you and your Spanish shit //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Speak English
translator.. that pretty disrespectful to think that by some unspoken notion that he HAS to speak English. your not entitled to anything. you say im a **** but that's pretty low..
It's a bot //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Auto Electric AUTONOMY UNLIMITED / UNLIMITED RANGE Electric Car,
First of all, receive coordial greeting everyone, all lovers of ecology and sustainable economic development, which should be very, very interested in the matter, and will not disappoint us go then to matter, what this car does is current flows through a coil in a closed circuit (not going to land but RECYCLE), then the coil to be parallel to the floor comes into contact with the magnetic field of the earth which induces current, so that the car can loaded even when this stopped, in other words, this is a generator without moving parts or a battery of unlimited duration, they want to watch, in fact, is not easy to believe, but if you do not believe, then you can check your same, in fact the controversy that will unleash going to be very, very strong so this simple evidence system, which is why you should check it yourself, which is also very economical, annex as evidence to prove the viability this system and how to check:
First of all, best, best regards to all, all the lovers of the ecology and the sustainable economic development, Which must be very, very interested in the issue, and you will not be disappointed, so lets go to the issue, all what esta car do is run current through a coil in a close circuit (NOT going to land but is RECYCLED) then When the coil is parallel to the ground it has Contact with the Earth magnetic field Which you induce current, so the car can be recharged even When is detainee, in other words, this is an electric generator without moving parts or a battery unlimited duration, how you like to see it, indeed, it is not easy to believe, but if you do not believe it, then a you can check it by yourself, in fact the controversy That will be unleashed is going to be very, but very strong for what esta simple system evidence, That is why You should check it by yourself, Which is Also very economical and easy, annex proof That proof of the viability esta system and how to do it:
- View the auto / See the Car
https://www.youtube.com/watch?v=ImhJL9VpT-4
- How to make the generator without moving parts / How to make the generator with out mobile parts
Google Translate for Business:Translator ToolkitWebsite TranslatorGlobal Market Finder
im gong to follow that what this that has been proven in a court of law to work and was swept under the rug.
https://www.google.com/patents/US4151431
Yes it's called suppression. Just like that guy that built a engine to run on water. Military hired him and it dissappered.
Bullfuckingshit //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
kmsl. you better put your hands on some **** and get out that liberal *** state. howard johnston has a patient and the water enigne is a real thing. water in one part oxygen and two parts hydrogen. remember the hybrogen bomb? not to mention you know the oxygen is a catalyst for modern day engines right?
jabuenrostro
GA
Papermaker85
