Ugh.. Not working..
Haha ok, good, I couldn't tell by your number of posts if you had been in to car audio long enough that you have to do that, I mean it's more like common sense,but I was just checking. lol
turn the radio on and go back and see if the sub is moving at all, like put your hand on it and feel if its vibrating. if it is, then your amp settings or head unit setting need to be turned up. is the amp a 2 channel amp by chance? if it is make sure oyur on LPF and that the LPF is set to about 80. and if its a mono, make sure the LPF is set ot aorund 80 and the Subsonic filter (if it has one) is set to the tuning of the box. if sealed you can turn it to 0 or w/e it is.
I can help you rule some things out.
It cannot be your remote wire or your amp would not come on. It could also not be your ground nor power wires to the amp.
Things it could be:
Even though you followed that wiring diagram, you DID realize it was all positives connected together and all negatives connected together?
Next, turn your low pass crossover to the highest value, or set it to "off" or "flat" Do the same in your head unit.
With a song playing, slowly turn your gain up. Do not turn it past 1/4 if you still don't hear anything at all.
Turn your subsonic to about 30-35 if you have a ported box and don't know what it's tuned to. If it's a sealed box turn it to "off".
No? I'm supposed to do that??
Just kidding //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Yes lol I stripped the ends of the wires
I know you did this, but you might want to double check that you stripped enough. This has gotten me before (not enough stripped). You also might check the output of the amp with a dmm to see if you're getting any kind of signal there.
Guess it was the gain. I thought I had turned it up enough but guess not. Thanks for everyone who put up with my slew of questions while I was trying to get this to work. Does giving the sub a break in period really help? Or can I start turning it up now?
Since you have sw out on the hu, you also have a xover for it. Turn the LPF to max or off, subsonic to a little above tuning for safety, I mean like 3-5 hz, just a cun t hair really
AConnelly09
Maryland Class of '13
AConnelly09
Baltimore, MD
AConnelly09
michigan born
    May 14, 2026
michigan born
    May 14, 2026
