Subs not working
EFighter808
CarAudio.com Newbie
I’ve been out of the sound game since high school so it’s been about 29 years since I did. But I recently installed subs into my truck and had a fairly new used 12” Rockford subs, a brand new boss amp (I know it’s a generic brand but tried to get the quickest amp I could find) and a china made stereo deck because it was the only one I could find that had the screen that I wanted. https://www.ebay.com/itm/3560118245...d=link&campid=5335951755&toolid=20001&mkevt=1 this deck came with a wire harness specific for my truck. Also no instructions were provided and I basically had to plug in whatever fit correctly.
I know for sure I hooked up all sound systems correctly from the subs all the way to the deck. The deck only has one green RCA cable that’s labeled subwoofer. I bought a y split and hooked it up and nothing to the subs. I also found 2 RCA cables that was labeled audio out L and audio out R, which I hooked it up to but still nothing.
The stereo is working completely fine and I changed the sound setting to have the subwoofers play but still nothing. Does anyone know how I can check to see everything after the deck is working properly? I checked ohms on the subs and both were reading 4 ohms. So the woofers itself should play some sort of sound.
Have you considered getting your signal from a rear speaker, run it to your amplifier then to the sub?
speaker tap wire.jpg?
View attachment 61178?
Unless those have a hidden resistance circuit (or your sub amp has high-level inputs), not the way to go.
You'd want an LOC.
That said, troubleshooting in the process of elimination. There are a limited number of things that can be wrong.
Keep it simple. Verify power at amp, and that the amp is powered up.
Do you have a phone (or DAP, radio, computer, even walkman) that has a 1/8" headphone jack?
If so, now get a 1/8"-to-RCA cable. Connect it to your player and to the amp. Set your amp gains to 75%. Play some tunes and slowly turn up the volume.
If you get sound, the amp is likely OK.
Now, you check wiring. Do a visual, but also swap in other cables.
Then you check all the settings on your head unit.
Report back here and people will offer more help.
EFighter808
CarAudio.com Newbie
EFighter808
Texas
RobGMN
