Speakers not working
Abilan17
CarAudio.com Recruit
32
4
USA
So I installed some speakers in the front doors of my car and they where working fine, but I wanted some more power so I desided to buy a small amp. I hooked it up and for the signal I taped in to my facotry speaker wires using a T-Tap conector and now my speakers won't play. Any suggestions of what's going on?
Sometimes to T-taps do not bite through the sheathing.
Just to make sure; you did disconnect the speakers from the headunit?
No, i didn't disconect from the head unit, I didn't want to remove the head unit thats why I used the t-tap and tapped into the speakers from the trunk, after i identified what was front and back speakers, left and right, positive and negative. I'm thinking the t-taps might have severed the connection meaning they cut through the strand inside the cables... I made sure that they would bite deep enough, maybe I went to deep???
For 1 I would recommend what 1aespinoza said to splice wires instead of t-taps
How exactly did you wire it up
You tapped into the speaker wire and ran that into the loc wires then ran the rca's into the aftermarket amplifier
Did you cut the wire that was going from the t-tap to speaker so you can plug it into the amplifiers speaker output directly?
Also can you confirm if you have the standard stereo or the upgraded bang and Olsfen stereo?
As of right now I cut the wire for my left front door speaker and iI connected the neg and pos LOC wires to it, RCA is connected to the LOC and the amp.Speakers are still hooked up to the factory harness at the door.
In have the standard stereo
Abilan17
Abilan17
USA
Abilan17
