Type Rs, which amp and box?
Bones33
Explorer
Im getting this setup for my car, I just want to know if you think it will run good
2 ... 12" Type - Rs
ALPINE SWR-1241D 1000 watt
(4 Ohm + 4 Ohm) 12" DUAL VOICE COIL SUBWOOFER
Kenwood KAC-8101D amp
- Maximum Output Power: 1000 Watts
- Power Output at 2 Ohms, at 14.4V (100Hz, 0.5% THD): 400 Watts x 1
- Power Output at 4 Ohms, at 14.4V (20Hz - 200Hz, 0.5% THD): 200 Watts x 1 AUDIO FEATURES
- Class D Operation
- Ground Isolation Circuit
- Quiet Turn-On
- RCA Audio Inputs: Gold-Plated
- RCA Line Outputs: Gold-Plated
- Selectable Infrasonic Filter: Off/15/25Hz, 18dB per Octave
- Speaker Connectors: Gold-Plated, Screw-Type
- Speaker Level Input Terminals: Plug-Type
- Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 18dB per Octave
- Bass Boost: Off/+12dB (90Hz)
im not sure if someone could help me, but do you think this box will go well with my 2 12"s? If you find something cheaper please tell me
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5747690703&category=50567&sspagename=rvi:1:2v_home#ebayphotohosting
or
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=50568&item=5748403824&rd=1
Pick a different amplifier. check out JBL, mtx, profile, us acoustics. U can find something nice for not too much money that would put out sufficient power but also better than kenwood as well.
Those boxes are horrible. The first one is just crap all together, and the second one is tuned to 45hz and will cost u quite a bit after shipping is done. I could just build you a custom ported enclosure for around the same price or better, and it will be 20x better than any pre-fab junk ud buy over ebay.
for the love of god dont get a bandpass box. also that other ported box is tuned to like 45hz isnt that kinda high for type R's? ive always heard to get them around 30hz
If you do not want to make a box you are probably better off buying a sealed prefab rather than a ported prefab. Also there are folks on here that will make you a box for a good price but I do not know if it will have that finished look.
These are alright sealed boxes for the money, there are better out there but they cost upwards of around $200+. These use MDF that is a little thin but with those subs you would probably be alright, you can always add some support to the panels inside with some MDF and wood glue.
http://www.crutchfield.com/S-3fjWWA7J0z6/cgi-bin/ProdView.asp?g=178650&I=044H1212DE
Well I found an amp which I think might work, its Profile. But can anyone else recommend boxes that are cheaper and ported?
New Amp:
Boss RT2500D
Max Power, 2 OHM 2500W x 1 chan. RMS Power, 4 OHM 900W x 1 chan.
RMS Power, 2 OHM 1500W x 1 chan.
Class D Power Supply
Signal-to-Noise Ratio > 100dB
THD 0.01%
Frequency Response: 50-300Hz
Dimensions : 8"W x 2 3/4"H x 15 3/16"D
Remote Subwoofer Level Control
RCA Line Level Inputs
RCA Line outputs
Variable Low Pass Crossover (24dB / octave)
Variable Subsonic Filter (24dB / octave)
Input Gain Control
Input Sensitivity Selector
Power and Protection LED's
or
Profile California AP1200
Peak Output Power(4 Ohms)-400W x 2
RMS Output Power(4 Ohms)-200W x 2
Peak Output Power(2 Ohms)-600W x 2
RMS Output Power(2 Ohms)-300W x 2
Bridged RMS Output Power(4 Ohms)-600W x 1
MOSFET Power Supply-Yes dual
Total Harmonic Distortion-
Signal/Noise Ratio-103 dB
High/Low Level Converter(Male RCA)-Yes
Pre-Amp(RCA) Outputs-Yes
Variable Bass Boost@45Hz-0-12 dB
12dB/Octave Crossover-HP/Full/LP
Variable LP Crossover Frequemcy-50 - 250 Hz
Variable HP Crossover Frequency-80 Hz -1.2 kHz
Bass Level Remote Control(16.4 ft)
Fuse(s)-3 X25A
Dimensions - 2"H x 10 1/4"D x 15 1/4"W
Power/Speaker Terminal Size(Gauge)4/6
not nearly that much //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Bones33 boss is junk. profile is much better and is about as cheap as ull get while still getting good qaulity and rated power. For the box like i said i build enclosures or there are others who do the same and it will be the best bet and cheapest for a properly built ported enclosure. u could go to your local audio shop but it will cost u much more than one of us could do one for. good luck.
I use to have the Alpine type R's Sealed, cause they sounded better to me, and I was running them off of the Alpine MRD-501. One for each sub. I found out though those subs truly want more then 300 rms. They like to see around 400-475. They are great subs.
I would go with that Profile since it looks like your sticking to cheaper amps. Then have it go around 400watts and 2ohm load. Then don't forget to wire your speakers in a 2ohm load.
Bones33
Explorer
Bones33
Albuquerque, NM
Echo42987
