Type R...dissapointed
Sorry your disapointed bro. It sucks when you go to all that work and you don't get the results you want.
I had a 94' Accord sedan that I put 1 Orion XTR12 DVC in a 3.75cu-ft box at 33hz. It wasn't bad for what it was, but I to
expected to much. Live and learn I guess.
Thanks. Thanks for everybody's help as well.
I'm satisfied with my setup for now though. Yes, I was expecting more but it's all good. I can always save up for an hdc3 if I decide I need more : )
i had 2 of them in my explorer in 6.5 cubes @ 32 hz running of a bxi2006d and i did a 151 on a ac190. they were definately some of my favorite cheapo subs.
Just played with my buddies 2 Type R 12's in an Eclipse. They did a 144.8 @ the headrest and a 147.2 in the kick with a zx1500.1 @ 38 hz. Keep in mind that this is a daily setup and my meter is hard. I don't see why you're having problems.
I used mine in 2.75 @ 37 and it was unbelievable for a $100 single 12". I was feeding it 1kw though. Check out the vid in my sig.
I hear ya, my friend has two 12" r's in a sealed box in his Hyundai and im not all that impressed with them, he is feeding 1000w rms total, 500w rms each. Many factors could have played a role in the sound though, it could be the box you have, the car you have and the power you are giving.
my one ported box with a single sub sounds like two subs. Having a custom box made specifically for the subs is very good.
K i'm getting closer. I set the Bass eq to 0. It did go negative, so 0 was in the middle.
I also discovered the subwoofer level adjustment on my HU, I thought my headunit had it but I hadn't found it til now. So that is set to max.
What about the bass level on the headunit? With it at 0, I get pretty low output. Cranking it to +6 (max) REALLY bumps it up. I'm assuming this will clip the sub as well? Can I just set my gains with it maxxed out to get a good setting?
you discovered your h/u has a sub level adjustment, but are the rcas hooked up to the sub out on the h/u? the adjustment won't affect anything if the amp isn't hooked up to it.
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
I have 2 12" R's and im pretty pleased with them. I have heard that once they are tuned lower then 34hz they start to lose intensity and its just kind of a waste. Next time tune it to about 35hz and ill bet you will be happy with the end results
7ender
7ender
Los Angeles/San Diego
jake21
