NASTY08IMPALA
No the hd is a 3" coil 1500rmsThe HD has a 4 inch to right?How about this, how many subs use a TI basket? Funny how nobody says they are the same.
My bad its the comp that has a 4 inch coil. Anyway the HD is a totally different motor and basket then the 9500.No the hd is a 3" coil 1500rms
Yea but the hdc4 is wayy diffMy bad its the comp that has a 4 inch coil. Anyway the HD is a totally different motor and basket then the 9500.
They are all different. THE HDC4 looks a lot like the VFL COMP but that doesnt mean anything.Yea but the hdc4 is wayy diff
u missed.my whole premise..not sayin the use the same exact parts dimbass..but the same quality on the hdc4 as theycr built in same roomThe VFL COMP and HDC4 look identical. They both look to use the DD 8 spoke basket. They both have 4 inch coils and the DD uses a 3inch. Therefor they do not use the same spiders.
HDC415-D1-A
American Bass - VFL- COMP 1511
I'm pretty sure they are made in China. They might share the HQ.u missed.my whole premise..not sayin the use the same exact parts dimbass..but the same quality on the hdc4 as theycr built in same room
No where am i comparing the dd9500 to the hdc3I'm lost. I've read you can believe everything you see online. I've also read AQ uses china coils DD uses US. I also know for a fact it dont matter where something is made if the QC is up to par.
Why do you need to recone your 9500s? I sure dont, not even luke warm after 30 minutes heavy full tilt. There are a few guys local running a M2 to a single 3500, its fine. There are guys local running M4a to a single 9500, 2 M3s to a single 9500. MANY M4as to a pair of 9500s and MANY M4s to a pair of 3500s. Mine dont even reach full xmax playing 7hz under tuningIf 3500s can take 2500 watts daily, why do I need to recone my 9500s running on 2500 watts/per daily? Eventually the surround is going to go, or something else, when you are pushing your subs to the limits. Power handling on subs, also comes down to the box.
Ya I dont know why we are here. I'm just letting my inner nutthugger out. I'll put it back in a few minutesNo where am i comparing the dd9500 to the hdc3
