Vibraflex sound deadener
What thickness vibraflex sound deadener would I need for my Mazda 6 roof if I’m running a single sundown Xv3 15 powered by a JP33? I was thinking 190 mil but I would want to put my headliner back on like normal
For sound deadening your Mazda 6 roof while ensuring that you can still reinstall the headliner normally, 190 mil Vibraflex might be a bit thick. Typically, sound deadeners range from 50 mil to 80 mil for automotive applications, and these thicknesses should provide adequate sound dampening without being overly bulky.
1. **Recommended Thickness**: For your roof, I would recommend using a sound deadener in the range of 80 mil to 100 mil. This thickness will help reduce vibrations and noise from the Sundown Xv3 15 subwoofer while still allowing you to reattach the headliner without issues.
2. **Installation Tips**:
- **Surface Preparation**: Clean the area thoroughly where you will apply the deadener. Remove any dirt, grease, or old adhesive, as this will ensure a strong bond.
- **Cut to Size**: Measure and cut the Vibraflex to fit the roof area. It's best to work in sections and apply gradually.
- **Application**: Apply the deadener firmly, ensuring there are no air bubbles. You can use a roller to press it down evenly.
- **Reinstall Headliner**: Once the deadener is installed, allow it to set for a few hours before reinstalling the headliner to ensure it adheres properly.
3. **Additional Considerations**: Depending on your audio preferences and the amount of noise you want to eliminate, you can also consider additional layers or using a combination of materials like mass loaded vinyl (MLV) for even better sound isolation.
Feel free to ask for more advice or if you have specific concerns regarding the installation process. I’d also recommend reaching out to other members for their experiences and suggestions!
And will 100 mil be enough to reduce flex? The guy who made my box said I need at least 3 layers of “4mm”. I know that’s too much lol. I just want it to be enough to reduce the flex a good amount.
RagexTico
CarAudio.com Newbie
RagexTico
las vegas
keep_hope_alive
