Okay i have this amp right.
Power Acoustik's BAMF amplifier series is the perfect amplifier for those that are looking for quality performance, while wanting to save some cash. Each amplifier in the BAMF series feature a die-cast aluminum heat sink that dissipates heat from three sides of the amplifier. For convenience, all the connections and control functions can be found on one side of the amplifier.
BAMF Series 2-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 220 watts x 2 chan.
2 ohms: 280 watts x 2 chan.
Bridged, 4 ohms: 560 watts x 1 chan.
Max power output: 1250 watts
MOSFET power supply
Wired remote bass level control included
Power and Protection LED power indicators
Adjustable Tuned Bass EQ (0-12 dB Bass Boost)
PWM Circuitry
Full Selectable Crossover (HI,Full,Low)
Three-way protection circuit
2-Ohm Stable stereo
Tri-mode capable
System Distress Indicator
Die-cast aluminum heat sink designed for massive heat dissipation from three sides of the amplifier
Platinum RCA level inputs
Platinum screw terminals
Variable high-pass filter (50-500 Hz, 24 dB/octave)
Variable low-pass filter (30-250 Hz, 24 dB/octave)
Subsonic Filter: 15-50 Hz
Signal to Noise Ratio: 97 dB
Frequency response: 10-30000 Hz
Dimensions: 11-3/8"L x 8-1/4"W x 2-1/8"H
--With mtx terminators.
.Description: Dual 12-inch, Terminator-loaded sealed enclosure
Impedance: 2 ohms
Frequency response (+/- 3 dB): 41 to 150 Hz
RMS power (watts): 400
Recommended amp power (RMS): 200 to 400 watts
MAX power: 1200 watts
Recommended amp power (MAX): 400 to 1200 watts
Enclosure size: 29.625 x 15 x 13.875
How would i go by setting these up?
No one can help me or figure this out so can someone be my hero
RMS Power Rating:
MOSFET power supply
PWM Circuitry
2-Ohm Stable stereo
Tri-mode capable
Impedance: 2 ohms
