Tweeters cutting in and out?
Hi I have the alpine cde-w235ebt and has one sub rca out put I have now bought the fusion 8” 600 Watt Super Slim Active Subwoofer
CP-AS1080 it has 2 rca outputs how do I wire this do I need splitters and where do they go any help will be apreciated
It is the tweets for the XXX component set that you are having the problem with? And you have double checked all wiring?
Bad solder joints in the crossovers? Bad resistors or caps in the crossovers?
Just throwing that out there.....
You may have to pull the gear to troubleshoot further.
Yes the re xxx tweets.
It's happening in both sides though ?
And seems to be over bumps, I think.
Just the tweets I'm pretty sure
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
8K
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
cbuts
cbuts
canada,ont
cbuts
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
