Tweeter Spheres - pics and examples
keep_hope_alive
Premium Member
Acoustics Engineer
I figured it makes sense to have a tweeter sphere thread here as well.
I started making another set last night, worked on them a bit more tonight.
I buy solid wooden spheres ($1.50) - like knobs or post tops, at my local Hobby Lobby. i hollow out a cylinder, (using Forstner bits, hole saws, dremel, etc.), drill a hole for threaded rod, and then... i'm not sure where to go next for a nice finish.
tools i use
i used double-sided foam tape to hold the sphere in the vice without making marks. works well.
I had to dremel sand the opening a bit larger in order to fit. the Forstner bit was either too small or too large. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
rods screwed in
wires soldered on tweeters
going with hammered silver paint (to match my painted interior)
painted and waiting (pic taken 2 hours ago)
i haven't decided how best to finish off the mount. there is a gap around the tweeter face due to it's construction. the widest flange is in the middle. so i need something to create a smooth transition. and then the grill - the Vifa doesn't have one. i have one, but it's larger than necessary.
previous work:
in the scion (temporary - we'll build another set)
threaded rods
mounting
aiming with foam and laser pointers
before Forstner bits - a hole saw first
then a paddle bit - we used two to create a ledge
then a dremel to smooth
currently i have spheres in my apillar pods - i can rotate and adjust aiming - some Rockford tweets
i also played with these old Alpine tweets
but i have this version (painted)
used to have them like this:
Siiiick!! I want. Price for a pair? Lol.
You should see my lame *** attempt with a ball o' yarn and some resin. Lmfao. Strictly experimental and with stuff I had laying around the house. Well, my Mom's house. I ain't got no yarn at my crib.
Here you go...
ball o' yarn.
little dip in the resin to make caramel apples.
little sanding.
Built in stuffing from the yarn that stuck.
Fitment.
aiming the tweeters toward you eliminates dominant windshield reflections.
firing across had reflection issues that resulted in phase interference.
reflections in the scion are off the nearby side window - which extends the soundstage width to beyond the side mirrors. it's cool.
the spheres in pods i have now are ok, but not ideal. course, they are just some random RF tweets i had laying around. they sound good for what they are.
I made a set of tweeter spheres using rubber balls. I needed a 1-13/16" hole for my tweeter flush mount cup, and the balls I found at the hardware store in the pet care department are just about perfect. $1.79 for 2. They can be cut by hand with a sharp knife and fine adjustments are done with a sanding drum on a Dremel.
keep_hope_alive
Premium Member
Acoustics Engineer
keep_hope_alive
Quad Cities, IL
tat2bass
