2016 Toyota tundra crewmax Space is very limited for a subwoofer setup
Head unit that I will be using is the JVC KW-Z1000W, It has some decent features that should work for me to not have to buy a DSP.
I am open to amplifier options.
I have looked at the Orion XTR 1000.4 it is rated at 165W X 4 can buy it for $240
or use the orion xtr 500.4 rated at 90wx4 can buy it for $132
I am looking at using a set of Alpine X - S65C found some for $500
for the subwoofer I am looking at a basic shallow mount supb10 inch. I would like to keep the subwoofer cost to $150 or below
Pioneer had some good reviews on some truck forums $110 for their TS-A2500LS4.
Amp for the sub should be able to keep it to 500w or less for a shallow mount. Plenty of options for $150 or less
With just the equipment cost
With the shallow mount sub in mind
If you had a budget of around $1000
for the components
amp for the components
sub
sub amp
what would you use
are there better options than what I am looking at for the money?
for the components
sub
sub amp
what would you use
