Trunk Rattles NEED HELP
venom107
The Graveyard Shift
I have almost got my Toyota completely soundproof but ther is one last thing that rattles. Its the key latch on the inside. I looked at it over and over to see if I could somehow stop it but Im stumped. My car would sound so nice if that would just quit so if there is anyone with a Tercel or any other car like it that has had this problem please help me. I was thinking about putting industrial carpet padding on the whole latch area but my subs are firing towards that direction and Im not sure if the SQ would ****. Thanks for the help.
If you have a trunk-pop switch on the inside, couldn't you shave off the lock cylinder? You could also try putting something inbetween the clip that holds the cylinder and the trunk, kind of like a shim, to make it a little more ridged. But, if you can afford it, I'd shave it.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
727
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
venom107
The Graveyard Shift
venom107
Independence, Kansas
MikeofTulsa
    May 18, 2024
    May 16, 2024
