Trunk car ported into cabin as loud as wagon/hatch?
  • 4
Suicide Bobb
SPLC Fails
Just wondering if porting my enclosure through the ski-pass, since my rear seats are sealed off, would potentially be as loud as the same setup in a wagon or hatch (in other words, something other than a sealed-off trunk car)? I guess that technically the enclosure I would be going for would be bandpass, since the subs are mounted internally? Sorry guys, I don't know much about boxes. School me ngas!
Yeah, I figure so, given that the first place the sound will travel to would be directly inside the cabin. The cabin space would be equivalent to that of a Hatch, without the added benefit of using the slope of the roof to direct the airwaves.
may want to take a look at the rear deck speakers and any venting there for loss. it may be possible to install speaker buckets, like gm used for a while. it also can prevent damage to the speakers...... just a thought
I built a bandpass for my BMW and only had the 3" port firing through the rear package tray. I cut a hole there and installed the port after the box was mounted so I could get it sealed off properly. All my friends can't believe all that bass is coming through the one hole. I am onlly running one 10" sub but it rocks enough for me. The best thing is to think it all out before you go to install. Hope this helps!
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
823
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
Suicide Bobb
SPLC Fails
Suicide Bobb
Camas, Washington
motomonkey
Decebal
    Jun 10, 2024
