Trunk build/wall?DD
  • 1
loudbalt
Hey guys new here! I have a 2006 chevy cobalt 4 door. Im wanting to build a wall but cant decide if I want to run 2 DD 3512s or 1 DD 9515 both sealed from trunk. I have all my wiring done 0 gauge I have batteries and getting a HO alt soon too. Im wanting to hit some good numbers on the term lab. Any advice/opinions would be great!!
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
688
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
loudbalt
loudbalt
Farmington NM
loudbalt
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
