Triple sub wiring on a US Amps XT4000D
ta2ed9783
Hey guys, I have three 10" Alpine type R's and they are all dual 4ohm. I was wondering if anyone knew if I could wire them all to 2 ohms and run em parallel to .6 ohms on a US Amps xt4000d? Can this amp handle that load? If not, could I run two of them to 8 ohms and the other one to 2 ohms and run em parallel to get a 1.3 ohm load? would this send too much power to the sub wired at 2 ohms? Any help would be greatly appreciated.
In comment to Garychoffmann, no, you cannot run the XT amps under 1 ohm. They will go into protect and get EXTREMELY hot if they don't. You can run 2 at 2ohms, wire them together to equal 1 ohm, and then series them to the other one at 2 ohms giving you a 1.3 to 1.6 ohm load. That's the best wiring configuration for that amp. The XT amps can't do what the traditionally made in the usa high end Us Amps could.
I hate wiring subs that way. some always seem to work harder than the others. I would consider going with just a pair, then buy another amp and sub to match then have 4 of them ******* in there.
I mean, Ive been running this amp at 1ohm hard as a daily driver and its never even gotten warm. What about a Concept cc-d1200? Would it be a better candidate for three subs parallel?
ta2ed9783
ta2ed9783
enterprise, al
ta2ed9783
