Transmission line enclosure build for 12" se
That's not true actually. Adding polyfil doesn't affect the effective line length. It will help dampen the response and smooth out upper harmonics. Transmission lines will have an oscillating higher frequency response with peaks and valleys. Adding damping to the line will help average those peaks and valleys and reduce the upper order harmonics and thus lowering distortion and increasing sound quality. Stuffing too much will have negative results though that could leave you with a loss in output and low frequency extension. Damping will also reduce output around resonance as well. It will also help flatten your impedance curve and draw the two peaks together to make one low Q peak.
Adding polyfil to a line that is too short will not help correct the problem.
wow that steave meade tutorial was fail then //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif i dont think anyone should use it.
I've been saying that for a while. You can still get good results from it though so it's not a completely bad thing, just very misleading and uninformed.
It's kind of sad that people rag on PWK transmission line designs when he has a much better grasp of 1/4 wave resonators than that guy does.
Im building a t-line for two 8"s. Ive had lots of experience with L ports and sealed enclosures but this is my first t-line. ive done loads of research and some have a chamber behind the sub, then with a small opening through the folded tunnel to a larger opening. Is there much acoustic difference between a simple t-line like your build there or one as described?
Cheers
would agree that pete has a better grasp, i just couldn't justify the design price.
Twisted_0912
Twisted_0912
NE ohio
Twisted_0912
