Too much load???
  • 2
Originally posted by beachboy016 Im planning on running two 10 w3's with a JL 500/1 or a JBL 1200/1 amp and 4 JL VR speakers off either a 50x 4 alpine deck or a 4 channel amp. My car is an '89 Jeep Cherokee, is this gonna drain it a lot and make my lights fade?
Thanks,
-Jeff
I had an 89 jeep cherokee once. Straight 6 massive battery and alternator.....if it is same engine I would not think it would be too much for the truck to handle. You should be good in setting it all up like that and really not run into too many issues with power. God I miss that truck it ran like a freakin tank!
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
beachboy016
beachboy016
Los Gatos, CA
Alaxan
    May 24, 2024
