To fuse or not to fuse
  • 7
GenY
CarAudio.com Recruit
53
USA
So, I got a new alternator and its rated at 257 at 1800RPM's and I got 2 fuses one rated at 250 and another rated at 300. I dont know if I should use either fuse or just use a bunch of zip ties running down the wire so it never moves lol.
How big is your power wire and amp?
Amps pretty good. 1000 at 1 ohm. I aint pushing the full 1200 though. Why you say need better amp?
If you want to get the max out of those subs then you should have at least a 2K amp. You are under powering them right now IMO. A good rule of thumb is two times the total rms of your subs. You have 1,200 total watts rms. 1,200 X 2 = 2,400 watt amp or close to it.
2 rockford fosgates P3D4 and a thunder 1000.1 ( 1000) watts at 1ohm
10's or 12's? I am pushing my P3D4 10's with a RF Prime 1200w amp @ 1 ohm. I am using a 300a circuit breaker near the battery and the 1200w amp has 120a fuse just before the amp. No issues. They hit pretty good but used to hit better in my G6 GT. That was a 125a alternator, I am using the stock 90a in this Elantra and you can tell big time that the amp isn't pushing as good as it was with a bigger alternator.
Thunder 1000... MTX?
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
578
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
Sounds like a bad ground or wiring problem on the 12v+ side.
13
GenY
GenY
USA
Bobbytwonames
vlusardi
    Apr 27, 2024
    Apr 27, 2024
