Time to get a new Sub
xKronicx
Hey I got to get a new sub because i notice mines has a rip in it. Not sure what from but it was a good brand sub Kicker. I might of had ht music too loud but who knows. Anyways I am trying to buy a new sub for my truck. I have a Ranger ext Cab truck and trying to find a good brand sub to get ? I am looking for a 12in if you all can point me into the correct directions or show me some good subs to get I would really appreciate that.
What a 12in to keep my box
Sorry needed to give more information. But i have a 12in box I made custom with MDF wood.. It is Sealed and i have a 1200w Crunch amp
Trying to get good bass well a upgrade from before. I was using the yellow 12in Kicker before..
Trying to keep it around 50-100$
I'd look at an SSA-Dcon... I'd imagine that amp makes about ~400w of power, so it should be a perfect fit. Maybe even a Dayton HO. Or an Sundown E-series. Any of those would be good bets. All of them are a little above your unrealistic budget. But they are all great woofers, that will last as long as your truck does if you have the crossovers and gains set properly.
Alright I will look those subs up.. But my box is 15.5 H and 16.5 L
Is there any good subs that will sound good in a truck box?
You seem to have a goal of asking questions but providing too little info to receive good answers. Even when pinned down on your box size, you only gave 2 of the 3 dimensions (so we still have no clue of its internal volume). Assuming you are measuring the outside, we need to know the thickness of wood you used also. Im confused how you built your own box, but cant give us an internal volume spec, or even seem to realize that that spec requires 3 dimensional measurements. For this reason, I will say another possible reason why your sub has ripped may be due to an improperly sized box.
Your latest post, the one I quoted here, is even worse, since 'truck box' usually refers simply to a trapezoidal shaped box designed to fit behind the seat in a regular cab truck. That shape alone does not lend itself to affecting the sound quality or dictate the performance of any given driver you would mount in it.
Im not trying to be an ass here, Im only trying to point out the errors in your logic that very well could lead to you making a mistake with your next purchase/install that could lead to another premature failure. I suggest hanging out here a little while and getting more of the basics of box building down before you spend any more money.
Cheers.
xKronicx
xKronicx
Lawrenceville,GA
naughtyca
