Thoughts of amplifier Power Acoustik RZ4-2000D
  • 5
What powe do u think ill het I need a very small chasis amp at leasr 100 per channel best at 125 I figured since its 160 it will do at least 120 per channel
If you're looking for small form factor on a budget, stick with PPI and go for a Phantom P900.4. Does more than 125 per channel and the same crossover network as on the BKs. Up your budget a bit over the PPI and you can get a Massive Audio Nano Bit 4-channel (those things are effing TINY). Otherwise, price no object, you're looking at the MMATS SQ4160. And that's an amp worth saving for.
If you figure that amp does about 50% of rated power it will probably work just fine. In that case 80W x 4 is still a fine amount of power. PM me if you want to spend ~$200 and I can get you a Precision Power P900.4 coming your way.
what do you mean by same crossovers as BK's? what are BK's?
Meant the PPI BK (black ice series) and the you have the same crossover adjustments on both the black ice and phantom amps which is more sophisticated than most anything in its price range.
I have not really heard anything bad about Vibe Audio. If you are buying it new, then no reason to not try it out. It may have a 3 month...
Polk DB seem to always sound so much better than most for drop inns...
810
I treat my vehicles to an extent where they become some of the quietest examples of that vehicle. It isn't cheap if you're buying quality...
naughtyca
naughtyca
Tampa FL
neo_styles
    May 16, 2024
    May 16, 2024
