Thought i would post some previous boxes i have built pics inside
Transmission line enclosures are not always going to use the Fs of the driver and the Sd of the driver for line length and line area. I wouldn't recommend taking that route as you will most likely end up with an efficient enclosure that is huge. You could easily get the same response and output with a ported enclosure that would be much smaller.
i know this. im just interested in the works behind these boxes so for fun im making a couple. thanks though.
well i would need to build my baffle out like 2inches to do that. i wanted to build the enclosure i calculated and then another using what i learned from the website indepth to see what happens. however, my depth has shut me down..
I'm going to be building a transmission line soon for my room and it's only slightly larger than my current enclosure which is 2.2 cubes tuned to 32hz. This is for a 12" sub.
Not having a ton of room isn't going to keep you from building some t-lines. You also don't usually tune to the resonant frequency of the sub.
mobeious
what does 0hz feel like?
mobeious
Bartow, FL
mobeious
