Thors 09 Build Log
Hmmm...Saw the score with the 2nd amp and it wasn't any higher than with your single amp....I guess this proves that more power doesn't always equal higher scores...I was thinking that maybe even with an extra amp the amount of air that is being moved is just marginal....I'm definitely no expert but just some thoughts I had.
8675309
possible to put the other 5k on top the box?
Nope too tall trunk won't shut.//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Actually I gain almost 2 decibels with both. For tests gain was set at half.
where do u put the silicon and foam?
Silicone along all box lines i.e. where floor meets box, where your side walls meets box, where top board meets box, and foam in sides between sidewalls and trunk, and along the top where the top board meets the back of the b-pillar.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
both amps strapped at .5 was able to find a 151+//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif That was with box pushed and sealed forward. Seems to be a solid .8-1.2 difference being sealed back so I'm hoping that once I get my glue and can really glue the spider pack down well
152+?//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Gotcha! I think I once heard that you generally have to double your wattage to gain 1 db....Is that somewhat true?
Close. For a general rule of thumb for every 3db you need to double your power or double your cone area.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Does not always work that way though!//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
thorshammer1
thorshammer1
Auburn, NY
uGotF-ckedUp
