Thors 09 Build Log
That port's a *****. It took everything you threw at it and still wanted more. lol
Balloons are coming soon!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Subs holding up alot better so far??
Much better.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif I also learned alot with with the last set.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
**** thats a good electrical system! what you have in there for your electrical?
Only thing added since we last saw ea other is the 2nd kinetik 2400. Alts from highoutputalternator.com 220amp tested at 170+ at idle:cool:
DAM! those little bishes have got some cajones! LOL, glad to see they are staying together now, good luck with the comps! Lets see a 154 baby! Gotta be some kind of record for 2 10's if you do it eh?
Equipment seems to last alot longer once you learn its limits.....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so you have 220 amp alternator and 2 batteries with 10K wrms and dont go below 14v?
3 total batts including the Optima Yellow under the hood. Gotta love zennon circuitry. Very efficient at 1ohm~ With both amps at .25 I drop to high 12's
pretty sure he didnt have it turned up lol
Had it at daily volume;) Original starting voltage is around 15.3-15.5v so 1.3-1.5v drops is pretty big:D
give me some flex viiiiiiidddddsssss
I'll work on it:D
Actually I believe there's a few CRX's that have run 10's and have done more than 154+ If I can get up there I would def. own the loudest trunk records.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
So far I have the loudest trunk in NY, and the entire Northeast US.//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif (Until someone gets in the lanes to prove different.)//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Very very true!//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Well had a pretty interesting day.
2 amps strapped at 2 ohm 149.2:crap: re wire them to .25 apiece roll into a 150.7 and pulled the spider ring off the landing:crap:
Since it came off so cleanly( lack of glue on spider landing, my fault) I centered and re glued it.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Back in the box it goes.
Pulled the 2nd amp and pushed the box back.
Test with 1 5k at .5 trunk un sealed
Test with same settings trunk sealed this time
Looks like box centered pushed as far back as possible and sealed is the loudest for my GP. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Final stages and a permanent seal job ( has shown to gain .5-.8) under way next.
thorshammer1
thorshammer1
Auburn, NY
uGotF-ckedUp
