The Saturn: Can't stop there. (Dual 18's upgrade)
Base for the back of the enclosure+port mounted in..
Port side and first port piece mounted to eachother..
The sides arent mounted yet...in these pics the port pieces are just sitting on the base
And had a fire...here's one of the cutouts for these baffles..
More tomorrow //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Took the dremel and grinded down the screw heads flat in the port so I can just body filler and sand it smooth..
Some body filler...not the prettiest thing but it'll all be sanded down..
Support piece..
Mounted..
Top of the opening into the port...got the piece cut for the top..
Mounted..
And mounted to the piece it butted up against..
Possibly more later but I have other stuff to do //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Looks like it's really coming together. I just picked up a first gen SL and plan on putting a monster system in it as well. Plan on putting 6000 rms in it but with the stock alt maybe 3000. Where did you get your dual alt bracket from and how much?
Drew
starting to look sick ! im anxious to hear this...
Thanks //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Are you going to be running SS 1-2 again the 17th?...this should be plenty ready for the comps this weekend //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif (atleast put together..its going to be a while before this is 100% sealed from the trunka dn finished up)
Drew
Thanks. And you gotz to make that ish, son //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif the dual alt setup will require custom work for both alt locations if youre going with over 200 amps for the stock location I would think it'd need a custom spacer-bracket type deal like mine.
i wish... i dont like the soundstreams i got so im switching... again. haha.:crap:its horrible... and unfortunatly i got rid of the mt's. so im stuck with s***... but the plan is to get a pair of FI ssd's . put them on a hifonics brutus bxi2006d and an 18 cubic ft box after displacement tuned to 30 hertz... ground pounder baby ! hopefully it sits around 147's on music.. then ill do little stuff like new H/U. maybe some dynomat... not really sure
Cool cool, my buddy had some SSD's and I was very impressed with them, you should like them. ***** about not having anything to compete with though //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Don't mean to thread jack but how long do you think my stock alt will last off of an HK4000D with two HC2400s?
Drew
I honestly wouldnt have a clue //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Whats the difference between Titebond II and III?
Looking good
Thanks and III is waterproof once dry and II is water/weather resistant...Im pretty sure the only difference is the waterproofness of them but III may also have a slightly higher pull-apart strength.
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
Those subsonic frequencies make a difference in how music sounds. Hearing the music and also feeling the subsonics adds a depth to music. You hear...
10
I just learned a couple of days ago that shark fin antennas are powered. Your issue may be related to that. Either the power to the antenna is...
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
4K
Pioneer~Saturn
Dr. Enclosure
Pioneer~Saturn
Dayton, OH
Johnny Law.Lulz
