The Official Type R Thread
If you can find some T/S parameters, you can do this yourself. I checked Alpine's site, and like all other name brand companies, they dont publish T/S data. SD is the cone surface area and I know you know that Xmax is XmaX. Just be careful, youll probably have to convert units. Most manufacturers only list one way XmaX and list the XmaX value on mm while they list cone sufrace area in square centimeters, inches or feet.
Uh.. are we talking driver displacement inside the enclosure, or are we talking linear displacement of the cone? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Well in that case, I would get a SWR-1222 and wire it down to 4 ohms. They can take on 1000 watts rms, just make sure its clean signal and not clipping.
As for how big the coil is, I cant remember
your saying the type r can take double its rms rating...god **** why even buy the type x hahahaha.
i have heard some spl boxes rather than a sq set up and the guy at the store said you tune the port high ....is he on crack?
too bad you dont know the coil ....its not on the site either cheese
Well he did say .071 cubic feet. No subwoofer could function properly in an enclosure that small, physics owns us.
I just bought a 12" type R (1222d). Looking at the sub and looking at the spec sheet boggles my mind. The spec sheet says .071 ft^3. This sub is freaking huge. I really don't think the displacement could be that small. Can anybody confirm this?
yes that is the correct displacement
the type r will take alot of power but i can most definelty smell the VC when its pushed hard for a long period of time, we just put a 12" R in my friends car with the 1000w RMS V12 alpine amp, and it straight hits, go by this rule, if it blow that just means its time for the X and you should be good
he's not on crack
the higher you tune it the more narrow the frquency response gets, and the sensitivity is raised,
50-80 hz tunings put out some high numbers but will not play music for shit-
but thats what makes hitting high SPL at lower hz more impressive
until the 20-80 hz rule was made for the db drags, alma gates set her world record a long time ago- 172**somthing- with a 120hz tone
What Jmac said. I said driver displacement inside the enclosure (usually just called 'driver displacement' in specs), I did not say enclosure volume. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif Make sure you know what you're saying before you make a smart *** comment //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. And yes its .071.
justchillin
justchillin
DC Metro
liquidswords
