T/S for fu subs?
Got them
FU750 cut out size
15" 13.875
15” sub
Recommended enclosure info:
Sealed ~ 2.0 to 2.5 ft^3
Ported ~ 2.5 to 3.75 ft^3 @ 30 to 32 Hz
FU750-15"
Re: 4.0 Ohm
Fs: 32 Hz
Qms: 2.9
Qes: 0.76
Qts: 0.61
Vas: 81
Le: 4.36 mH
BL: 21.3
SPL: 87 dB
Sd: 856 cm^2
Mms: 321 g
Xmax: 20mm
Power Handling: 750 watts RMS
I tried loading the info from him into winisd and there's like 6 inconsistencies, as well as a few of the parameters being nowhere near what's fu lists them as.
Any idea what unit they're using for VAS?
That's the problem, there's an issue with the numbers I got from them. It can't auto calculate because one or more of the measurements aren't right or something. I turned autocalculate off and only entered the info from fu, and it still has half a dozen inconsistencies.
I had no issues entering it in, you also cannot enter it straight like that, you have to enter a number in, hit TAB on your keyboard and let the program do its calculations. You cannot enter things in manually and expect it to work.
Here's what i got. Green numbers entered in; Blue numbers are auto calculated after pressing tab,
the box specs given by FU audio are good for daily loud. For an SQ flat response box, I see a 5 cubic feet box tuned to 28hz.
What would you do? The punk I listed to is almost no bass at all, so when I want bass I put on some older dr dre or something with a good bass line. SOmetimes even techno. Just want to get loud more than sq, but that 28hz at 5cu has a hell of a resp. curve, waaay better down low. How many sq in per cu ft for the port? I was trying to stay around 15 per...
At 20mm xmax I'd go higher. 16 would be better imo.
Leave on annotations
I had the same problem. It was driving me crazy. Every time I ran the numbers it would give me a message that the numbers was wrong. I checked and rechecked with no change. Now if I can get a chance to try it again I can get this box finished.. Wish I would have seen this sooner. Thanks for the info Jeff.
I have no problems modeling enclosures for these subs in Termpro ....
I've got a set of these in 3.25-3.50^ft test boxes and they play hard all the way down into the 20's .....they are both tuned in the low to mid 30's ....
kcr357
kcr357
ft laud
Boominburban
