system keeps cutting in and out
Dlux
Kingpin
hey, i have a 12" MTX 5500 sub - 300wrms
and a MTX Thunder 600xd amp
it keeps cutting in and out when i crank up the radio
the little red light on the amp is staying on (for the most part....it will flicker once or twice after it cuts off)
im not SURE but i believe the guys at the audio shop installed it with an 8 gauge power wire to my battery (i dont know but its a red soundquest wire and on the outside it just says EIGHT)
my amp is pretty much always hot, but its black and i live in pheonix, arizona....
when i crank up the volume my battery voltage meter goes down when the sub hits if its a song that hits hard. when it gets to about 10 or 11 it cuts out, until i turn it down n let the meter rise to 13 again.
i had my alternator checked and they said it was fine.
btw, i drive a '97 camaro
i can post pics/videos if needed.
my friend kinda has the same issue. When he turns up the volume, his bass keeps on pounding but all 6 speakers shut down, while the car is filled with bass. I'ma check his ground, then again all his wires are everywhere in the trunk.
when that volt meter drops to 10 or 11 thats bad. your amp is recieving voltage under 11 volts and thats whats causing it to go in protect. did you upgrade your electrical system?
before you keep on letting your amp cutoff like that, id upgrade that ish before you kill your amp
dude if you are getting 10-11 volt drops with 300 watts.....lmao
turn down your bass boost all the way on amplifier and turn off LOUD on your head unit...that sounds like the problem to me
Dlux
Kingpin
Dlux
Scottsdale, AZ
BigE
