System Is About Done (pics)
Alpine CDA-9815
Well this is pretty much the first install I have done without help //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It's pretty much done. All I really have to do is carpet the floor for the trunk... not sure if I should go with black or try to match the OEM carpet already in there. Gotta clean up some wires. Then I need to finish putting the rear interior in and install the steering wheel controls. Oh and of course get with Ant from Second Skin for another Damplifer Bulk Pack to do the trunk. I will add a 6 disc CD changer later... I already miss my OEM one.
I had a few issues with the amp rack. I had to redo it 3 times... the vinyl kind of got messed up but I'm just happy to get it all in and working. If it bothers me that much I will take it all out and revinyl the amp rack, right now I can care less about it.
HU- Alpine CDA-9887
Components- JBL GTO 6.5" (needed 2 ohm to run off the stock HU for awhile, they will be replace when I get the $$$)
Rear Speakers- JBL GTO 6.5" coaxial
Sub- 12" Fi Q
4 Channle- Memphis 16-PR100.4
Mono- Memphis 16-PRD1000.1
PAC SWI-JACK (steering wheel controls)
150ish sqft of Second Skin sound deadeners
KnuKonceptz wiring and RCA's
A few pics of the car...
http://pic50.picturetrail.com/VOL440/1612587/15701262/238891090.jpg
http://pic50.picturetrail.com/VOL440/1612587/15701262/238890993.jpg
http://pic50.picturetrail.com/VOL440/1612587/16834243/259922932.jpg
http://pic50.picturetrail.com/VOL440/1612587/16834243/259922963.jpg
I see places that need more deadening //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
And modeling clay...
More deadening will happen... but not a lot, keeping the weight down on this car.
Moldeling clay? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
what woofer is that? a BL?
Guess I forgot to add what sub it is... 12" Fi Q.
Looks pretty good man. I'd put a couple more holes in the amp rack for the wire comming off the amp on the drivers side so it looks like the one on the passenger side. If you can, I'd go for factory matched carpet too.
How do you like the KnuKonceptz wiring? I'll be buying all my stuff soon. Just looking for opinions.
doesn't seem that the sub has a good path to put the bass into the cabin
There is 5 3"-7" holes from the trunk into the cabin. I thought it would be an issue but the sound gets though pretty well. No way was I going to give up my rear seats for subs in this car. It's better than OEM, that's all I wanted.
Just another observation, you're losing a ton of potential midbass output because of that large hole in the inner door panel //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Seal that up with sheet metal or Plexi, along with the holes above it, and I bet you'll get better results...
Alpine CDA-9815
Alpine CDA-9815
BFE
Alpine CDA-9815
