Sundown Full Bridge Stuck in Protect Mode
From what I've read its rated at 1 ohm but not recommended
I'm not sure what subs your running but can you change it to 2 or 4 ohms and see if it still happens?
Just so you know I'm not just pulling this out the air here is a quote from an advertisement for the amp
"The new SFB series is being kicked off with a 3000-watt mono. This is a "full range" mono ideal for "PA" type speakers as well as standard bass applications. It is very compact at ~8 7/8" x ~7 5/8" so also great for tight spaces. It is not suggested for operation under the rated 1-ohm load. This unit features full sized 1/0 power inputs and high-quality metal control knobs to set it apart from other models in it's class. This is a budget line and We are working on other, larger, models for this line as well -- stay tuned for those details."
The ad says, "under the rated one ohm load." So, .67 or ½ ohm load is not recommended.
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
mahc
