Sundown Full Bridge Stuck in Protect Mode
From what I've read its rated at 1 ohm but not recommended
I'm not sure what subs your running but can you change it to 2 or 4 ohms and see if it still happens?
Just so you know I'm not just pulling this out the air here is a quote from an advertisement for the amp
"The new SFB series is being kicked off with a 3000-watt mono. This is a "full range" mono ideal for "PA" type speakers as well as standard bass applications. It is very compact at ~8 7/8" x ~7 5/8" so also great for tight spaces. It is not suggested for operation under the rated 1-ohm load. This unit features full sized 1/0 power inputs and high-quality metal control knobs to set it apart from other models in it's class. This is a budget line and We are working on other, larger, models for this line as well -- stay tuned for those details."
The ad says, "under the rated one ohm load." So, .67 or ½ ohm load is not recommended.
669
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
marc2112
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
