Sub?
RickDog
14
al
Yes I have a Question: I want to run one Kenwood 10" and Im goin to push it with a Kenwood 600W or a Kenwood 1000w amp. I looked on there website and I only saw two diff. types they make. But my question is what type of box should I use. I listen to alot of rock. I have GREAT!! sounding mids and highs just need that bump added in with it. Im looking for good SQ but I also want it to ROCK. If i use a sealed how much air space should I put the sub in??? If a ported box is need what cu.ft. should it be built to and what should I tune it to. Thanks for any help..
THIELE-SMALL PARAMETERS
- DC Resistance (Re): 3.1 ohms + 3.1 ohms
- Electrical Q Factor (Qes): 0.4
- Force Factor (Bl): 16Tm
- Mechanical Q Factor (Qms): 5.25
- Moving Mass (Mms): 3.03 oz
- Peak Excursion (Xmax): 9mm
- Resonant Frequency (Fs): 30Hz
- Total Q Factor (Qts): 0.37
- Voice Coil Diameter (d): 1-7/8"
- Volume Acoustic Compliance (Vas): 1.517 cu. ft./43 liters
SPEAKER FEATURES
- Bumped Yoke
- Dual Vented Voice Coils
- Extended Pole Piece: Sprial-Vented
- Frame: 1.2mm Thick Steel
- Frequency Response: 25Hz - 700Hz
- Impedance: 4 ohms + 4 ohms
- Magnet Weight: 42.3 oz
- One-Piece Cone Design
- One-Piece Rubber Surround and Gasket: Extra-Wide
- PBO Advanced Fiber Cone: 10" Mirco-Weave Silver, Tornado-Type
- Power Handling: 1,000 Watts
- Sensitivity: 92dB
- Speaker Connectors: Gold-Plated, 2-Way SB-Type
Thats the specs on one of there subs...
Well i have a friend that has a slot ported box and it has one ten in it and it is the hardest hitting ten that i have ever heard, so i would like to have a alot of output on that ten if possible.
Originally posted by RickDog Well i have a friend that has a slot ported box and it has one ten in it and it is the hardest hitting ten that i have ever heard, so i would like to have a alot of output on that ten if possible.
we wouldn't know the outpuf of that 10" since we weren't there to hear it.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif wat was the recommended ported box size for that sub?
well i really dont know, but i know it was a xtant and it had like 3.0 cubic foot of airspace he didnt know the tuning freq
do people jsut ignore my posts???
i actually took those numbers and put them into winISD, lol.
those are for nice flat responses... you want more output from taht 10?
go as big as you can, (2-3 cubes looks decent) and tune it around 35 hz...
yes...listen to this guy..he knows more than me..:eek:
Originally posted by GSteg yes...listen to this guy..he knows more than me..:eek:
thank you, finally some respect around here //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif lol
those were numbers that i got froma program, i didn't just pull them out of my behind, l ol.
Originally posted by Goddyd4me ohh really???? i figured u jus grabbed numbers out of the air and threw them together.....u mean u actually base your responses on real info??? maybe i should start doing that...heh
whil.e they may be more accurate taht way... it doesnt seem to mean that you get any more respect or attention doing it like that, lol
Oh my bad, I really didnt know you figured that up for me. I really thought you were kinda guessing, based on tens, but thanks.
RickDog
RickDog
al
Wonderbread
