pinkbear
OK so i got done installing my new kicker CVX 12 (2 ohm) which is rated 750rms. i hooked it up to a new hifonics 1000.1d ( 1ohm 1000, 2 ohm 750 , 4 ohm 500) after installing it it didn't work.
yes i hooked it up right parallel wiring so it should be 1 ohm load now. using 4 gauge wire and 12 gauge on the sub..
could it be the rca cable??? how would i check it if its bad?
i was pissed! so i took it apart and started messing around with it and it started hitting but barely.. just a little movement.. i tried adjusting everything but nothing.. its like i need to turn the gain up but there is no gain knob ha!
idk what it is any help please. i don't want to have to take it to a shop. that charges 85$ an hour for something that maybe i can do.
