I have just installed a fosgate p3d4 12 in a belva prefab sealed box. Yes i know there are much better subs and a custom made box is recommended which i plan on doing. Haven't had alot of time or money to put into it so it works for now. Got a prime 500 amp powering it running of a Pioneer fx700bt hu. However it sounds really weak on real low bass. For example playing "put on" by young jeezy the 3rd n 4th bass notes are pretty much inaudible. On sum of the higher bass notes it pounds n im pretty happy with it for the most part. Just doesn't get low enough though. I've tested all wiring and grounds and everything is pretty sound. I'm thinking alot of its maybe the box, but when watching the voltage output from speaker leads im getting around 25-30 volts on some of the higher bass and sub is hitting pretty hard but when lower notes hit its dropping all the way down to 10 to 5 volts and the sub is barely moving which makes me wonder if its something to do with the amp or head unit output. The amp has a built in infrasonic filter so can't change anything there and my lpf is set to around 100 hz. I'm not expecting this setup to rattle my rear view mirror off but really feel like it could be better. Any input is appreciated
