hot_inferno
Like the sticky above says, im new //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I know a bit of this, a bit of that bt not much..
Anw i found this sub that i like bt i have absolutely no idea what these values mean:
Thiele & Small Parameter
# Impedance (ohm) - 4
# d (mm) - 217.0
# d (inch) - 8.5
# Rdc (ohm) - 3.3
# Fs (Hz) - 26.6
# Qts - 0.41
# Qes - 0.43
# Qms - 8.4
# Vas (l) - 52.5
# Vas (cubic ft) - 1.85
# Mms (g) - 132.3
# Lvc (mH) - 1.1
# Xmax (mm) - 6.2
# Xmax (inch) - 0.2
# BL - 12.7
Anybody care to help? //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif
This is the site i got them from if u need it:
http://www.caraudiodirect.co.uk/product_info.php?products_id=2184&cadid=0862d550e8829b999b7bcbb074e9b756
(in the tech spec)
Help will be greately appreciated //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
# d (mm) - 217.0
# d (inch) - 8.5
# Rdc (ohm) - 3.3
# Fs (Hz) - 26.6
# Qts - 0.41
# Qes - 0.43
# Qms - 8.4
# Vas (l) - 52.5
# Mms (g) - 132.3
# Lvc (mH) - 1.1
# Xmax (mm) - 6.2
# Xmax (inch) - 0.2
# BL - 12.7
(in the tech spec)
