Sub Size For Rock/Techno SQ?
ctmaudi
For mostly rock and techno (once in a while a little rap) what would give the best SQ but still be loud? I was thinking of grabbing an SAZ-1000D with two SA 8 D4s. Then double them if I wanted louder down the road.
I like my RE SE, but it just doesnt seem active enough, or quite loud enough, especially with rock/techno. Its taking 750w @ 2ohm from a Kenwood amp. Im getting a reall good amount of money for it, the amp and box, so Im starting fresh.
Im a noobie, and not sure which sub size or brand has better SQ for the music I listen too though.
Going in a 2010 Nissan Rogue, its a lease so got to be stock charging (could probably get away with the Big 3 if needed).
Space is a concern. I dont care how tall the box/s are, but they cant be that long or wide. The back seat is split folding, I keep the one seat behind the drive up and fold down the passanger and middle section. Id like the box to fit behind the one seat thats up, maybe a little wider if needed. Ill get a pic in a bit, and try to measure.
Budget is not set in stone, but Id say around the $600 mark if I stretch out over a couple months, but cheaper would be better. Trying to find a good used amp for $200ish in the classifieds.
Never built a box before, but Ill get to that when it comes.
Thats the space I have. The box I have now doesnt fit long ways how I want, and it blocks off a lot of the cargo room I need.
Just got two new SA 10 D2s on the forums here. Looks like Ill be getting a PA P2250D to power them, probably run 1500rms .5ohm.
Will my stock Rogue handle it?
ctmaudi
ctmaudi
Akron, OH
ctmaudi
