sub recommendation for ported 1.25 cu ft @ 35 hz
kerpit
I built a box that is 1.25 cu ft tuned to 32 hz for my boat. I specifically built it for a dc level 3 12 sub. I did not know that with shipping it was going to take over 3 weeks for dc to build the sub. I have a trip planned may 14th and want a sub for this box! I'm searching for a used dc level 3 12 currently and haven't found anything yet. Is there another sub that would work in this box? I really want to stick with a 12 and $350 max. I will be powering it at 1k watts rms @ 1 ohm. I have found a level 2 12 and a level 4 12. But I think the level 4 needs 1.5 cu feet...
Any help would be greatly appreciated!
thank you for your time
Brian
I'd like to stay with a 12 if possible because I cut the **** hole already!!! Lol. Would a sundown sa12 just sound horrible in that small of a box if ran on 1k watts?
A ten(10) would perform so much better in that enclosure than a 12 in my opinion.You are limiting yourself on finding a 12 that will perform at its best with that small of an enclosure.Id recommend on making a baffle and cutting the hole out for a 10(Its just a sheet of wood placed over the existing cut out?Carpet it or?).You will have many more options and better output/performance.Open up your options instead of limiting them..Hell, a pair of 8s will get down in that enclosure
roger that, just got one from sonic electronix for $189. thanks for the help
18
This $100 over your budget but it checks every other box https://stereointegrity.com/product/bm-11/
10
I ran 2 10’s aero ported in my 06 mustang years ago. Each box was 1.2 and the subs were diamonds (can’t remember exact model). Best thing to do is...
10
235
383
kerpit
kerpit
Geneva,Il
Jeffdachef
    May 16, 2024
    May 16, 2024
