Sub problems
Just pulled it out. One voice coil as soon as you move it it jumps to 30ohms. The other jumps to 11ohms. Not sure what they should read during movement
The resistance is constantly changing while the coil is in motion... Are you sure your wiring was all tight an none of the wires fell off while installing? As he stated take a good look at your leads
Wiring was all good. I even pulled the sub out, checked the connections and reinstalled it. And again the new sub was MOVING, the used one barely moved. Actually looked like the new one was using it as a passive radiator.
They each have their own airspace, sharing a port.
[quote name='AnthonyO']Got all the wiring inside the enclosure done today with all 8gauge. Even did the POP test just for you @Massive spl ;
Didn't get it back in today cause my back gave out. ***** being old with a bad back.[/QUOTE]
Blame it on bearscat bakery lol... And the sitting in the patrol car
i did a little bit of wiring today too
lol
They both popped the same direction at same time?
AnthonyO
Budget Banger Connoisseur
AnthonyO
Minot, North Dakota, United States
els1989
