Sub Problem?
  • 2
MrPeezy
I Have 2 Zv5 18’s & I Was Just Testing Them On A 3k Tramaps 1 Ohm . One At A Time Not Both To 3k . All I Get Is A Pop/Spark Under The Cone When I Turn It Up & Protection Mode. When I Run My 2 12’s Sa Sundowns They Run Fine On The 3k . Is it a coil problem. Or is it because I wired a 2 ohm amp to a 1 ohm sub I know I’m not supposed to do that but it shouldn’t pop should it ?
You said Your 3k is a one ohm in second sentence. They you said Its a 2 ohm amp...which is it. If your sub load is One ohm it’s going to try to pull one ohm load from that two ohm amp. You trying to ruin your amp?
No I Was Just Trying To Test But Is That Not Going To Work .Single 1 Ohm Wired Sub & 2 Ohm 3k
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
558
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
666
That does sound similar to what mine does, I'll take a video and post it this weekend so you guys can weigh in.
23
5K
138
MrPeezy
MrPeezy
Florida
BCotrell
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
