Luna
I actually had a system installed for me in my new 2005 Accord, I really don't have the time to do it. I had Best Buy install it and low and behold they messed it up big time.
I have some Alpine Component speakers along with an Alpine Type R 12" sub. I have a 2ch Alpine amp for the front components putting out 70wx2 and a Kenwood amp for the sub that's putting out 500wx1 @ 4ohms I believe.
After they got it installed we gave it a listen and the front components have a lot of noise in them. The source does not matter, XM, CD, FM/AM. Even if the volume is set to 0 it still has static. They told me it might have been a defective RCA converter kit. I'm using the stock head unit which has no RCA output jacks so they had to wire in two kits for it, one for the sub and one for the components. I actually fixed this though by turning the GAIN down to 0 on the amp which removed almost all noise (there is just a tiny amount that you can't hear over the car itself while it's running). By doing this though the speakers no longer match the sub and are overtaken (I have no volume knob for the sub yet)
The other problem (main one) I'm having is that when I power the stereo off the sub turns on full blast and will only go back to normal use if you turn the stereo back on or if you turn the car off which will power the sub off. After playing with this I noticed that if I pull the rear seat down this would go away and the sub would hum on and off very slightly. The second I pushed the seat back up into place the sub shot to full volume again. Maybe a wire is being pushed up against something, or there is some kind of interference?
Thoughts are welcome though as I might be able to fix it myself or at least point them in the right direction. I need to make them install a volume knob for the sub anyway as it really overpowers my speakers.
