Sub isn't working..?
brian1226
i have an alpine type R 12inch (4ohm + 4ohm) sub and was using a sony xplod http://www.xplodsony.com/xplod/amplifiers/XM-2002GTR
my sub started shutting off and on about every minute then eventually got worse until it finally didnt work anymore.. my amps protect mode was on (which means the positive and negative wires are touching even though they werent) what could be the problem with my sub? i know its probably not blown.
well i actually tried another sub on it and it worked fine for a while.. the sub actually shut down once soo i disconnected it b4 it started to damage it.. could my amp be burning sumthing up? its wired in the 2ohm setup but my amps manual says nothing about 2 ohm wiring
brian1226
brian1226
medford, ny
brian1226
