sub for small volume in a big box???
rollertoaster
PA
I'm currently using a power accoustik fubr 12 in a 1.70ish cu/ft sealed box. I just wont hit low enough, the res freq is only like 33hz on this sub. Plus, it's old and I think it's getting a little loose. I'm looking into getting an elemental designs e5.12.
here's the specs
Qts: .40
Qes: .42
Qms: 7.00
Fs: 21.0Hz
Re: 4.5
Vas: 69L
Mms: g
Bl: 17T*m
SPL: dB
Sd: 545cm²
Xmax: 25.4mm
Voice Coil: 50mm
600w rms
I'll be running it off an eD 600w rms amp.
my box is oddly shaped and totally sealed up so I can't take it apart. Can I put something inside to decrease the volume? Do I have enough volume to port it? I'm leaning towards sealed due to the odd shape of the box I wouldn't be able to have mush port length.
here's the box
Nick can build to your VC specs.
Thanks, that's a possibility then. My only problem would be the port then, I don't have much depth to deal with in the box only about 8 inches, I'd have to do it with pvc and a elbow or something. I'm not sure I'd have good results.
What would happen if I ran the eD sub in an enclosure that is too large?? Couldn't I just put an object of high density inside the box to displace volume to bring it into spec?
The elbow works fine, seen it done before. You could displace with a filler. As far as the eD sub goes, i've never ran one, so my opinion isn't worth $.02.
Thanks, no one has run the new eD yet, it's not out yet.
1.7 cubes is too big for most 12's sealed, and on the small side for porting. Invert the sub and run external ports and you might get away with it. Otherwise yeah, just put some wood inside it to reduce the volume and stay sealed.
a focal polyglass 33v2 13 inch sub will go in 1.25-1.45 ported. it isn't an spl sub by any means, but it sounds nice in small ported boxes. most of focals ported box subs perform in smaller boxes well.
edit: i'm wrong. the 33v1 is the ported box sub. the 33v2 is better sealed.
rollertoaster
rollertoaster
PA
azimuth
BP1Fanatic
BP1Fanatic
