Sub Excursion, space requirements......
SlickCMRick
Ill be givin my type r's about 850watts of clean power each, and i have a box now that may be too big. I think the subs will cause excursion that will make them smack against my trunk lid. I haven't got my amp yet so i can't see, but i only have TWO INCHES between my trunk lid and box. Pics below
I was thinking of going with something like this, the same box, but only 4 cubes and 50 inches of port area , the major differnce is this one is 6" shorter in depth.
my.php
Opinions? I was also thinking of firing them into my seats (seats would be down) but I don't know if there is enough room for the port's air to circulate the trunk
You should be cool man
Just make sure you have your box secured so it can't move
Only way to really know is to try it
Its like being in a room with a closed door, you can stand around talking about how it may be locked, or just go up and turn the knob, nah mean
CT
if i were you i wouldnt only secure it but i would also remove that little bit of plastic at the back of ure trunk... the thing i dont think anyone thot about when they said that it would be ok is that ure subs arent gonna be flush mounted so it acutally sits away from the box a bit prolly like a half inch to an inch... so i would bolt it down as far back as it will go and give em plenty of breathin room.... BTW POST 700
SlickCMRick
SlickCMRick
Las Vegas
PowerNaudio
