B bigmack2007 10+ year member Senior VIP Member 328 0 Montgomery, AL Jun 13, 2007 #1 Would 1 nice 15 like a RE XXX or a DD9515 be louder and hit lower than 4 bottom end powerbass 15's? Click to read more...
LowLowBass 10+ year member keep it simple 317 0 SEATTLE, THE GREAT NORTHWEST Jun 13, 2007 #2 I'd go with XXX!!!!!!!!!
Blove1991 10+ year member CarAudio.com Elite 1,849 1 North Carolina Jun 13, 2007 #3 Install and box dependent. Coil area of 4 VS Coil area of 1 How much power is the 4 seeing. How much will the 1 see And if you got 4 now then why not just get 4 9915's or 4 XXX's
skadude016 5,000+ posts CarAudio.com Veteran 7,430 13 Canton, GA Jun 13, 2007 #4 Install and box dependent. Coil area of 4 VS Coil area of 1 How much power is the 4 seeing. How much will the 1 see And if you got 4 now then why not just get 4 9915's or 4 XXX's Click to expand... //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif ???
OP B bigmack2007 10+ year member Senior VIP Member 328 0 Montgomery, AL Jun 13, 2007 Thread Starter #5 I'm powering the 4 with an a3000db amp. So there seeing around 2000 all together. Would one XXX at that same wattage be louder and hit lower?
skadude016 5,000+ posts CarAudio.com Veteran 7,430 13 Canton, GA Jun 13, 2007 #6 I'm powering the 4 with an a3000db amp. So there seeing around 2000 all together. Would one XXX at that same wattage be louder and hit lower? Click to expand... its more box dependant. but DD's seem to be naurally louder.
D dipitydoo 10+ year member CarAudio.com Elite 564 2 St. Louis, MO Jun 13, 2007 #7 All subs in their proper comparable enclosures, a single sub will not likely make up for the severe difference in cone area of (4) subs, given the same total power.
